Re: Automatic transmission
Not really (at least not in Europe). Getting it rebuild (assuming it's not cracked the housing or something) would be an option. If it's very badly damaged, then you could hunt around junk yards to find one from another SVX, then likely get that one rebuilt.
Alternatively, you could get a AT from another Subaru, you'll also need to get the matching diff, as the SVX drive ratio is fairly unique among Subaru automatic transmissions. This will change from characteristics of the car, it will rev higher on the freeway, but you'll get more acceleration, and maybe better gas mileage (unless you like the additional acceleration, in which case you'll probably get worse gas mileage).
Good luck!
