View Single Post
Old 05-03-2019, 11:23 AM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Re: Mystery Warning Light
Yep. It’s on my Emerald, an there isn’t one on my red. Have reached out to Young Tom. He must have added it. May be related to my Hydra.
