View Single Post
Old 12-04-2017, 09:17 AM
Re: ABS shaking everytime I press brake pedal since rear wheel bearing change
Originally Posted by THE NEW GUY View Post
Hello Guys,
Since I changed my rear wheel bearings some months ago, I noticed my ABS is activating every single time I brake. First the ABS light came on so I added some spacers to reduce the distance between the ABS sensors and the target crown. after that, the ABS light does not come on but I feel the ABS pump is activating each time I brake, right at the point when I release a little the pressure on the brake pedal. During summer, to avoid this anuance, I removed the big fuse of the ABS pump, but now, in winter, with all this ice, I need my ABS back so I replace the fuse and the problem araised again. Do you think one of my ABS sensor was damaged during the bearing replacement process?
Any comment will help.
Thanks.
Yes, Damaged sensor would be my first guess...
