Funky Tach
Since replacing the intake vacuum lines my tachometer hasn't been working properly. While in drive the tachometer won't go above 2k rpm. Mechanically, the car seems fine. While in Drive, shifts are as expected and the speedometer works as it should.
When in park the tachometer operates as it should, however in drive is when i have an issue.
Any thoughts?
