Re: What else would I need to use this for a 5 speed swap?
I just finished installing pedals from a 2004 WRX. Not sure how they compare to a Legacy. Really not much to modify on the pedals, at least the way I did it. There was an extension at the top of the clutch pedal that needed to be cut off and that was all I did. The big issue I had was getting the gas pedal to work. The top of the lever that the cable fits into sits too high and hits the tube carrying the clutch shaft. I had to grind the top of the lever as much as I could and then file out the bolt holes on the gas pedal bracket to it would slide down far enough to allow lever to clear the clutch shaft. Maybe other ways to do this but that is what I did.
Also, getting the pedal assembly positioned correctly under the dash is a lot of work. Wasn't sure it was going to work at first but eventually got it.
Good luck.
