Originally Posted by herffstyle
HOWEVER, he did say that the NYS inspection computer does allow 2 or 3 registers to be "Unready".
This is completely unrelated to the MIL. 1996-2000 vehicles are allowed two monitors to be "not ready" in NYS.
[He] thinks there may be a chance that the NYS computer will know the difference between the MIL being set because of Emissions or because of Other issues. AND it may allow the Other issue.
He doesn't know for sure.
Are you willing to bet a major driveline reversal on it?
You can experiment with this - disconnect the trans from the engine ECU, get MIL lit, hook up for inspection. If it passes, you can do whatever transmission thing you choose, albeit with a perpetually lit MIL. If not, you're stuck with stock.
A better alternative if you want a different driveline?
Sell your SVX and buy an OBD-I car. Modding an OBD-II car in NY means reversing it every year, and you'd have to be pretty hardcore to swap your transmission every year when there's a much simpler alternative.
