Re: Brake light stays on
Originally Posted by ColoSVXer
but the "Stop Lamp" still comes on when I press the brake pedal even though all lights illuminate. ??
Try changing all four of the brake bulbs, matching them to the same wattage.
The stop lamp checker uses the amperage difference between the trunk panel and the two body mounted stop lights to determine if a bulb is 'bad'.
If you have unmatched wattage bulbs, the difference in amperage can be enough to trigger the checker, even if all four bulbs work.
Bulbs are dirt cheap so when I have one go out, I replace all four with the same brand.
1996 Polo Green LSi #216 ..138,100 miles. ..SOLD
