Re: Jdm cam vs usdm cams.
I would think that the cams may be different, as you don't have 96 - 98 octane available in most of USA.
or if the cams are the same then the pistons may be different - to give compression variation?.
anyway that is my thought....
If you use JDM ones you might need to add fuel additive to stop pinking..
