Thread: Engine Rebuild
View Single Post
Old 12-06-2015, 01:14 PM
longassname's Avatar
Just some dude.
Significant Technical Input
Re: Engine Rebuild
Because I like aluminum bearings. I don't just like king bearings I like the particular bearing set I gave the part # for. I've used them in almost every EG33 I have ever built. You might note I've never had one fail. Granted that's probably because of the precision of my machine and assembly work as the bearing itself but you can certainly be confident that if you use that bearing and have a failure it was because of you and not the bearing. I've already proven them extensively so you can eliminate them as a question mark in your build...why introduce uncertainty that isn't necessary?
