Re: ft. axle seal off the transfer case.
I tried installing the axle like that once, the axle doesn't work as well as a "push" slide hammer, since then I've used a rubber mallet or block of wood and hammer to reseat the stub, then install the axle the normal way.
It does work that way though, so give it a shot...
