Re: ATF Pan leaks, 96-97 cars
Originally Posted by Blacky
I changed the fluid and filter on my '97 and used the gasket which came with the aftermarket filter. Over the winter all the fluid leaked out because I had not tightened the bolts enough. Better than over tightening though.
No leaks since then in 12 plus months.
Did you remove the Fujibond from the pan and/or the transmission case before using the gasket?
1996 Polo Green LSi #216 ..138,100 miles. ..SOLD
