Re: Phenolic Intake Manifold and TB spacers for the SVX/EG33 coming soon
I'm afraid so. Can't help myself. Have to keep it automatic, this time, and emissions compliant, and able to traverse a pothole without sending me to the dentist. But, who knows might make the /Drive channel one more time. Won't make Bring a Trailer again unless it goes up for sale and I won't do that if I can restrain myself enough to keep it viable as a daily driver.
