Re: Unexplained battery drains
That's definitely a possibility. Another issue I've been having is that I get in and turn the key...all the lights come on but nothing happens. No click or anything. I turn it a few more times and then the starter engages.
It doesn't start slow or anything, it sounds like a nice strong starter, it just doesn't do it the first couple of times that you try to start it.
I thought it was my ignition switch going south, but maybe not?
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
