Re: Towing manual trans SVX on tow dolly
if the drive shaft it out, no issues. leave the back wheels down on the road.
4 bolts to take the shaft loose at the rear diff, but you could loose gearbox oil up front without shaft (depends ) so take a hog pan to let it drain into with it out before you take off.
you cannot leave the driveshaft connected and dolly a car on the ground, the center diff will burn up.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
