Originally Posted by EdWindows
I'll upload pics when I get home.
I've maybe put about 1500 miles so far and no corrosion.
They have attracted a lot of dirt due to the light coating of moly grease I applied to the shock bodies in order to prevent the aluminum adjuster rings from seizing to the steel threaded shock bodies.
The powder coating is really tough too! I lightly knocked off some dust with a wire brush while adjusting ride height and it didn't seem to harm it.
Also compared my new BC racing coilovers for my E30 to the Ceikas, and the craftsmanship is on the same level. I do like the adjuster/lockrings from Ceika better though.
How about those pics? I hope you're home by now anyway
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with
DCCD &
VSS,
ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels,
17x8 BBS STI Wheels,
PERRIN CRANK PULLEY,
911 Turbo oil filter,
$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines,
DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,
Window scratcher fix, JDM Clear Corners
