Re: Failing aftermarket fuel pumps
Originally Posted by Huskymaniac
Guys, this sounded like the most likely culprit in my latest SVX saga. Drove the car home last Friday with no issues whatsoever. The next morning it wouldn't start. The starter ran and the engine turned over. I "think" I didn't hear the usual fuel pump noise. Should this be the first thing to check? If so, how do I get to this connector?
Tony
Spark, Fuel, Air ...
1. You've confirmed the engine turns over
2. Pull the fuel line from the fuel filter to the fuel rail -- crank and confirm that you've got fuel pressure
3. No fuel pressure - pull the back seat bottom and check to see if you're getting voltage at the pump when the key is on
4. Voltage good? yeah, replace the pump
5. No voltage? start back tracking the circuit
6. Good Fuel pressure at the fuel rail? start checking your sensors that will prevent correct spark events -- temp sensor, crank sensor, cam sensors -- you're looking for the correct resistance across each sensor. If you're lucky and can acquire them, replace them - one at a time - checking to see if it will start after each replacement.
Good luck with it!
Bill
Retired NASA Rocket Scientist
Center Network Member #989
