Re: Dag nabbit @#$&*$!
Well, if the injector wires are burned I'd think the problem is there.
Or is the fusible link located at the same spot?
The chip is what you need to swap. It has all the new maps. But the ecu needs to be modified a little.... you need to remove the original ROM and install an empty socket for the Stage 3 ROM to be pressed in.
It's really simple - you just need to be careful.
/T
