Originally Posted by theflystyle
There are replacement lenses (ebay) that are clear but do not have the beam patterns in them. You could also go the better route and get glass headlamps from Germany.
Just out of curiosity, when you refinished your plastic lenses, did you apply any protective films to the headlamps?
No, I just used Mequire's cleaner and polish after very fine grit sanding to remove the yellow haze.
Thanks for the heads up on the ebay lenses. I think I would want a good beam pattern.
I haven't thought about applying protective film.
