Re: How much $ have you put into your SVX?
Car Price: $1,000
Modifications/Maintenance (Oil changes NOT included): $5,770.81
Wiring Modification V.4- $75
Rally Armor Basic Mudflaps $25.35
Polyurethane 80H F/R swaybar bushings + Rear Differentail Mounts $110
Mcmaster car 4138T57 Hood Lift supports-$42.99
Cross drilled & slotted discs w/ ceramic brake pads F/R- $170.03
12V 3A 16mm Red Symbol&Circle LED Black Metal Switch-$5.69
10x T3 Red Neo Wedge SMD LED Light Instrument Cluster-$12.99
10Pcs T10 168 W5W 5 SMD 5050 Red LED Car Wedge Tail Side-$4.49
10x T5 74 Red 1-LED DASHBOARD CAR LIGHT BULBS-$1.99
4pcs 32MM SMD 6 LED 3021 3175 Festoon Dome Car Light Lamp-$5.98
Goodridge SS Brake Lines- $83.50
Hayden Transmission Oilcooler Flex-a-lite $28.99
ECUtune 4.44 TCU $230
Clear Corner JDM Lights- $155
Quickchange-$140
Halo Prosport Gauge $61
Clear Corner JDM Lights- $180
Rear subframe $15/15Min Mod- $12.75
(2) N62/Z32 Nissan 95-96 300ZX TT-$70
(8) 370cc side feed injectors- $175
Velox Wheels- $600
GMAX AS-03 225/45/R17 $425
Perrin lightweight crank Pulley- $95
Passenger OEM Inner Door Panel Cover- $9
OEM Cup Holder -$9
F/L wheel well- $40
JDM Fuel Pressure Regulator $22.95
Waterfall Grille LED- $18
MAF- $67
Front Driver side & Passenger side CV Axle- $150
2 Rear Hatch Trunk Lift Supports- $65.90
Stereo Cage + Passenger Side Sunvisor-$55
4.44 tranny swap + rear differential LSD- $800
AWD Transmission Linkage-$1000
VSS1 &VSS2- $240
Used Door sills-$64
Water pump + Timing belt+ Hydraulic Tensioner+ Idlers + 2 accessory belts (a/c, alternator) -$260
Optilux XY Yellow Fog Lights H3-$15.04
DDM HID 9006- $32.50
95 Subaru SVX owners manual-$69.80
Drivers side seat adjustor-$15
Tint Windows- $80
Lexani LX9100 225/45/R17 -$300
Owned it for 5 years
$1,354.16 / Year
$112.84 / Month
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels, PERRIN CRANK PULLEY, 911 Turbo oil filter, $15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights, Window scratcher fix, JDM Clear Corners
