Originally Posted by cruisen_15
I'm thinking this is bad headgaskets and cylinder leakage.
Do the gas test for the cooling system to verify. Cheap and easy.
If your reservoir does not bubble or you do not loose coolant then how could this be the reason for the high temps you are seeing?
/T
