Originally Posted by david_12121
Thanks for the info...learned a lot
Regarding the clutch basket, based on the pictures I've seen, the other 4eat's are pretty beastly around there...don't seem like something that would break so easily...is the SVX one different? Also if it's welded, instead of the shock the chatter creates, however small, you have continuous transfer of torque...
Cuz I know MANY people do the removal and then just the selenoid mod and go drifting...I know that's a crappy idea so I thought the welding would be better at least...was not aware of the other weak links
I know they can be made to take power but it's not worth the money for me, since I won't be keeping it.
you can not remove the front cv axles, the wheel bearing will fall out.
yes you can break the rear clutch basket The ones you have seen are from what years? I believe in 01 and later, Nate or someone else can tell you for sure, they use the VTD type transmission which is much stronger and all around a better set up. Unfortunately in the early years they wanted a AWD that could be put on a 2WD dyno.
