Re: SVX Engine cooling "Again & Again"
A substantial increase in bypass flow capacity might not be a bad idea to try. Maybe controlled by a solenoid valve - open above 4500 rpm? Might not be that difficult to arrange. There are big plugs in the lower surface of the block. The pump inlet can be drilled for the fittings. Eh? T
