Re: Oil filter revisited
I have seen discussion on going into bypass on the NASIOC forums, but can not find it juts now...... The small four cyl filter was too small for high revving engines with increased pump capacity.
If your engine is clean and ok and oil (+filter) changes frequent, I do not think the higher by pass pressure is a problem.
BTW, after I did the HG job and cleaned the engine internals the oil looks still clear as new after 2000 miles.
Cheers,
Tapani
