Re: Which Outback should I buy
Originally Posted by 1986nate
If you believe that, then you've been drinking the Subaru Kool aid for way too long. They never have, nor would have ever fixed it, hence going to an all new engine design that follows in the footsteps of the EZ30.
As to a response, without seeing them in person and checking them over, who knows. No one can anser that question over the interwebs. However, I would be going with the 06 Bean out of the 3 if I were buying blind.
I recently read that Subaru finally switched to multilayer gaskets, I believe, in 2010. If that is true, it could be reason to believe the problem will be much less frequent.
Tony
