Originally Posted by BackWoodsBob
Found 2 td04's for <150 each. Thinking of running them both under the car. Swap the manifolds side to side, rotate them, bolt the TD's up, run an oil filter sandwich plate which would effectively feed and draw oil from the turbos, T off a coolant line and go to down.
Only problem is the MAF, which, if I'm correct you could just swap straight with an MAP sensor without issue.
instead of removing the maf I'm going to use it for tipin enrichment, seal it against boost and clamp it.
