Re: SVX difficult to start
The temp sensor is located under the left rear of the inlet manifold. On the water cross-over pipe. There are two temp sensors there, one with one wire, that is for the gauge, and one with two wires (the one you want) for the ECU.
With the engine cold, you can undo the sensor and replace it. You should be able to do it without too much water leaking out, just top it up after it has run for a few minutes.
One Arm Bloke.
Tell it like it is!
