You're in luck then, Reberto.
Since you're putting in a Subaru Forester radio the sub harness plugs into that radio no problem.
You will need the forward adapter to connect to the SVX's radio plug coming from inside the dashboard.
Get a pre-wired adapter from Dave Carter (he has a wide selection of options) to splice to the Sub harness or just get the connector and move the pins.
http://ae64.com/Ordering.htm
Let us know how it all shakes out. I'm glad I did it. Mounting under the passenger seat fills the car with strong lows or thumps as the music requires. And in fact I had to adjust the sub gain level lower to get a decent balance with the cabin speakers.
As for the breakout box, my 10 CD changer's FM modulator is screwed to the side of the transmission tunnel under the carpet in the passenger footwell. There's a lot of room for coiled up cables and components under there...not so much on the driver side where the antenna connections are.
Another thing you'll need is a short antennae extender cable from the radio to the RCA connectors under the carpet.
The Forester Radio is not diversity so it's up to you and testing whether to connect to the retractable antenna or the one imbedded in the back glass. One or the other, do not use a Y joint to gang both antennas together - it confuses the radio.
1997 Ebony Black Pearl LSi, 80k miles (129k kilometers), JDM clear corners.
1994 Laguna Blue Pearl LSi, 149k miles (249k kilometers), blown tranny, likely using bits and selling as donor transplant project.
2006 Newport Blue Outback XT Ltd 117k kilometers, lowered 2.25" on OEM Legacy GT suspension.
1994 Emerald Pearl LSi w 2006 WRX 5 spd manual.
1997 Laguna Blue LSi, 46k miles (73345 Kms). One owner 25 years, always garaged, pampered and 9/10 showroom condition. Possibly the last Canadian spec Laguna ordered #100134
