Well, sadly that was a failure. The sunroof was stuck in the vent position, and while trying to manually slide the glass back (no manual override, so I had to literally pull on it) to get to the remaining bolts, the plastic bits in the rails broke and the glass cracked. But here are the photos I did get of it!
The slightly ghetto button arrangement
The factory light buttons were wrapped up in duct tape and shoved into the headliner...
Socket where the factory dome light went
And this is how it was rigged into place. Classy eh? You can also see how they mangled the roof pillars to get the drain tubes in.
