View Single Post
Old 04-03-2013, 06:01 PM
showoval showoval is offline
Re: Another shuddering/ binding question.
Originally Posted by oab_au View Post
I think you need to be sure of what is happening when you say this,
"I noticed it more during traffic and it's more prominent during slow turns under light to heavy acceleration now"
If this shuddering happens when travailing in a straight line, it is not the AWD system. It maybe the gearbox mounts.?
If it only happens when turning, then it can be the AWD system. As far as the cost over there, maybe $500.00 to do the C solenoid/Transfer valve, and the clutch plates.
Once again Harvey, thank you for your responses. It definitely does it while turning that is for sure. And the straight light is only when crawling or lightly acclerating,but the shuddering is barely noticeable. I want to say that it was there prior to feeling the worse shudder on turns. The gearbox mounts could be why the heat shield vibrates tremendously during crawl speeds (0-20) and the pinging sound coming from the drive shaft well area.
01- Impreza RS Original Owner
92- SVX LS-L
