Re: 8 pot brembo calipers
They are an addition to the 6 pot brembo kit Ive made using a minimum 34x355 rotor and using the same (slightly modified) mounting block as the 6 pot kit, they will offer even more clamping force then the 6 pot though.
These are the same 8 pots seen on lambo's and Audi r8's etc and should be cheaper to put together then the 6 pots if you buy second hand calipers with my mounting blocks
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
