Re: Roll Cage in the SVX
smc:
Those photos aren't from an SVX, are they? Haven't ever seen an SVX inerior stripped naked, but, this geometry doesn't look right.
By the way, any opinions on my seat choices, Cobra Daytona or Bride Euroster? I think they will result in a significant drop in seat height.
