Originally Posted by icingdeath88
If you want to delete the EGR, the most difficult part will be getting the line from the pass. side exhaust manifold out. Once you do that, you can just put in a bolt to plug the hole. I tried and I tried, but I could not get that fitting to loosen. Still haven't quite figured out how to solve that problem. Gene, what did you do?
Did you try using this?
Combined with a crow's foot wrench, it might do the trick.
EDIT: Sorry if the images are annoying. I'm bored with text. :P
