Re: Select Monitor (ssm1/OBD1) USB Cable
Originally Posted by BackWoodsBob
There are a few of us over on rs25.com who are slowly but surly working our way to boosting our EG33's, or at least wanting to eventually tune.
Someone brought up this morning using a USB to SSM adapter. But that it could be made with a regular old USB cable, does anyone have input on that claim?
Sounds dubious to me.
The ECU requires a 5 volt TTL signal. Somehow you need to convert the USB signal to the TTL signal. The normal way to do this is to use a special USB to TTL cable. These are not expensive, usually much cheaper than the Legacy Audio cable you have to attach to the end.
I have heard that some older cellphone USB cables output a 5v TTL signal.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
