Re: East Coast-based 24 Hours of LeMONS/CHUMPCAR World Series SVX Race Team??
Ouch. I can't imagine that tires count in the $500. The Hankook Ventus V12 evo K110 has a 280 wear rating, and it is only $114 at that size, but the ratings are really bad. What is the size of the existing wheels on the reX?
