Originally Posted by NSTG8R
Well, even a '97 is still 25 years old. I read in one of the posts that a 25W 27 ohm resistor worked the best (original between 12-15 ohms). All I can say is that the part was cheap, the job was easy, unless you knew what you were looking at it would seem stock, and most of all my tranny shifts beautifully between 1st and 2nd for the firts time since I've owned it . If I could ever locate my camera cord, I'd take a pic for you.
May want to check your math. Last I checked 1997 was only 15 years ago
Originally Posted by B 4 You
I'd rather not splice anything if I don't have to. Since mine is a 92, should I get a resistor from another 92? Or should I go for a 97 since it's a later year and probably a better resistor?
All resistors are the same spec for OEM.
