Originally Posted by Kiss Me Deadly
i did a check. when i check for EXISTING codes, power light flashed infinitely. when i check for previous codes, it show me code 25.
after few attempts to check, power light didnt blink anymore after start, so there is no existing code in tcu. But now i have a new big problem - car hiccup after 2000rpm, and i cant raise rpms more than 2500 like i have craps in air intake on turbo engine. i have a QC, but i didnt touch wiring and resistor behind battery
heeeelp..
i remember yesterday, when i tried to start engine (about 20 attempts) the power ligh started to blink in the middle of process
Based on your previous cam sensor wiring issues and these symptoms, I will tentatively suggest double checking your cam sensor. When I had one with the cam sensor starting to fail, it would have similar issues.
Will the car stay idling or will it die after a few seconds idling in park? Try unplugging the MAF and see if you are then able to rev the engine normally.
