Well to sum it up I haven't driven the pearlie in 2 months because of this. The voltage fully closed one way is 1.3 and open at 2.3. Now I suspected a bad tps so I switched it with one from my red car and got the same results.
The way it drives is like it wont shift right because of the tps being so off and when you give it gas like WOOT it cuts all power and kicks in after a sec then revs to high rpms and takes forever to engage the gear, again i'm assuming because of the tps. Any help is appreciated cause I really would like to get this thing back in shape. Thanks.
