Here's how I wired up the DCCD controller. I hope this is acceptable.
You will be left with 4 wires. Ground, 2 DCCD wires, and the E-brake cutout.
You will have to find your own ground but this shouldn't be hard to do as there are a bunch of spots to ground things in the ECU/Fusebox area.
Obviously Hook up the 2 DCCD wires to their counterparts.
For the E-brake cutout, I powered up the car and used a test wire to see which one would activate the cutout. There is plenty of room on the backside of the connector to do this.
Comments, Questions?
