Re: Intermittent engine cutting out.. ???
I still have slight bumpy starting to accelerate.. BUT about 90 to 95% of that went away.. on its own??? NOW.. just initial lag/jerky start.. smooths off after the very initial acceleration (used to last .. 50 to 150 feet.. about 40mph!) ..
Maybe the air intake valve .. or aux intake valve.. ??? [I've sent for used MAF by member here.. but.. ??]
Please lead me to info on those.. links?
Thanks, Jim
Jim
