Can you drop this engine into an SVX?
http://www.ebay.com/itm/JDM-EJ20T-VE...item256abac217
It looks like it comes with everything including the ECU. I suspect, however, that this ECU is not compatible with our TCUs (or maybe it is compatible with the OBD2 ones...).
What would be involved in such a swap? If I am correct, these engines were rated at 300HP.
Just curious.....
Tony
