Re: Intermittent engine cutting out.. ???
Unfortunately... .. . MY CAR WUNT RUN WITH THE MAF DISCONNECTED!
So.. It's still cutting out every few minutes (at the least!).. .
SHOULD I CUT THE TOP OFF THE MAF .. TO RESOLDER ??
Could this be an intermittent failure of the fuel pump? It acts very similar to when my gas gets low .. and then "runs out" early (ever since I replaced the pump 1-2 years ago) .. ?
Thanks, Jim
Jim
