Re: "stop lamp" light
Have you replaced a burned-out tail light recently?
The stop lamp checker uses the amperage difference between the trunk panel and the two body-mounted stop lights to determine if a bulb is bad. Very similar design to a GFCI outlet in your house.
If you have unmatched wattage bulbs, the difference in amperage can be enough to trigger the checker even if all four bulbs work.
Bulbs are dirt cheap so when I have one go out, I replace all four with the same brand.
This is the easiest place to start.
1996 Polo Green LSi #216 ..138,100 miles. ..SOLD
