Re: Bontrager Works 22mm rear sway bar kit
Originally Posted by icingdeath88
One alternative was used and seemed to work well, but was found to possibly interfere with the banjo bolt on the brake caliper, potentially a very big deal.
I don't see how a different end link setup on the bar alone causes clearance problems. The nuts on the ends should be close to the same with either setup.
But if the bar is one inch longer (48" as opposed to 47") then the mounting point, where the links attach to the sway bar, end is 1/2" closer to the banjo bolt on each side.
1996 Polo Green LSi #216 ..138,100 miles. ..SOLD
