View Single Post
  #250
Old 10-13-2011, 05:23 PM
sunvalleyray sunvalleyray is offline
Re: Bontrager Works 22mm rear sway bar kit
OK, It was the top bolt that contacted the banjo bolt at the brake line on the passenger side caliper.
It did not break the bolt, but nuged it enough for a fluid loss, causing the pedal to go to all the way to the floor, slowly.
Perhaps MY Nevin bar is wider than the rest?
When I get the chance to work on my Pearlie, I will measure the width.
Evan with the adjustable links reinstalled and at their shortest adjustment, there is only about 1/4" of clearance between the top bolt and the banjo bolt.
On the drivers side its about 1/2".
Huck, I really dont want to bend a hardened bar.
A set of 150-155mm links would fix it on my Pearlie.
John, the suspension is stock and the springs and struts are in good shape.
So sagging is not an issue with it.
OT,
Thanks for the update. I will go out to the garage and measure the distance between end link bolt and banjo bolt, hopefully that will help.
Ray
