Re: alternator wires
Originally Posted by Gamesy
what are those wires in the plug for?
On the plastic connector, one wire is the field sense wire, that energizes the alternator when the ignition is on. Also monitors battery voltage and uses the regulator to supply additional voltage on demand
The other wire goes to the idiot light on the dash, turning it off when the alternator is charging.
If you are replacing the plug, make sure to keep the wires from getting switched around. Remove only one wire at a time and reconnect to the new plug to avoid confusion..
The original OEM plug has two wires of different thicknesses, the replacement plug has both wires the same size. Mark them however you want when changing them.
1996 Polo Green LSi #216 ..138,100 miles. ..SOLD
