Re: Building it up only to let it go - those who've jumped ship. *LONG*
Haven't had my car on the track since I spun a bearing a year ago. Engine is rebuilt. Runs fine, but failed emissions. Long story, but it could pass emissions, if I could get a helpful shop that would let me bring it in warmed up and do the sniffer test right away. My goto shop here broke their sniffer, and it isn't worthwhile for them to replace it for the occasioal OBD1 car that might come through.
So I drive it once a month at night when the cops can't see my lapsed inspection sticker. It is still the same wonderful driver with gobs of torque that I remember from my Watkins Glen drive in May of 2010.
I'll probably soon get around to registering it as a collector car in NJ, so no emissions test, but only 3000 miles per year allowed. At that point, I'm going for a very good quality paint job., and that will be the last mod. Don't know if I will take it to the track again. Takes the entire weekend, and I've got other stuff I want to do. Maybe after I retire.
Regrets? Yeah, a few. If I put this much money in a Porsche 968, it would be a track terror.
But, it sounds great and handles fantastically, and, in the hands of this inexperienced driver, is both forgiving and exciting on the track.
