Originally Posted by fun173
Sorry for the thread bump.
If I swap A4 and A6 I will not have to ground it at all, correct? Also, How do I re-insert the wire? Do I need to push in the clip and slide it in? I have a 97 so I a going to follow post #174.
From what I gather. Swapping the wire will turn the manual mode button into a power mode button by only switching A6 into A4. Is this correct?
When you’re laying on the driver’s side floor mat looking up underneath the dash, you should be able to see the black connector. You’ll know it’s the right one if it has the brown wire going into A6 and has the empty slot two slots over (A4) as shown in my first picture. IIRC, after you remove the pin from A6, it should just slide right into the empty A4 slot and click into place. That’s all you need to do and then you’ll have power mode by using the manual button on the shifter (which works great by the way).
