Re: Contact cleaner
Originally Posted by Blacky
OEM is Bosch.
That is not consistent with what I have read in other threads and my remaining OEM sensor does not look like the Bosch sensor. I think denyo said in another thread that others have claimed that the ECU seems to only like OEM sensors and that NGK and Bosch have caused him the same issues. The Bosch sensor I used for Bank 1 Sensor 1 seems to be working fine as a replacement. This appears to only be an issue with the extra sensor (sensor 3) that only the OBD2 cars have. If the code returns I will probably swap sensor 2 and sensor 3 to see what happens.
Tony
