Re: Contact cleaner
Originally Posted by dennyo
My 96 has been doing this for a few years now. I've tried bosch and ngk sensors,cleaned all the contacts except at the ecu,cleaned the injectors and nothing has worked.I even cleaned the bungs so I know they make good contact on the cats.It returns every 2 drive cycles. Just like the FSM say's it will. I just clear it when it pops up.next step is exhaust. It runs fine but uses a little more fuel than normal.Btw, the code I get is po145. Good luck and let us know if you figure it out.
I had the contacts cleaned and greased with contact grease. If that doesn't work I am going to contact Bosch for a replacement. But I am wondering if the problem isn't related to mismatched O2 sensors. Both bank one sensors are now Bosch but I am guessing that the bank two sensor is OEM.
Tony
