Re: Cylinder 6 Misfire
Originally Posted by Ironhydroxide
Um, no, REAR Left Side of the engine. IIRC the Engine goes as such
Front
2 1
4 3
6 5
Back
OH, and another weird thing....While I was having Crank angle sensor problems (or when I pull the crank angle sensor out of the hole without disconnecting) the Engine throws TONZ of codes (which i would expect) BUT the interesting part. It threw EVERY Injector SAVE #6 (maybe because i had #6 disconnected while cranking because of the problem I've had).
Have you tried swapping an ignition module from a known working one?
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
